JINXRCAT
Mar 02, 2023Aspirant
I bought my R9000 for the NAS aggregated connection to it
I bought my R9000 for the NAS aggregated connection to it. I wanted file access and storage to be of high importance. I'd love to see a collection of suggested Netgear configured environments for t...
JINXRCAT
Mar 03, 2023Aspirant
I was just adding my comments to my use of the R9000 with my Network Storage Device. Ethernet port aggregation between two devices allows your devices to treat multiple Ethernet links as if they were a single link. Sorry for not explaining my use.
I am no Guru in any of this equipment. I am an OLD dog, that spent 40+ years in the technical support profession.
I would agree ethernet is the safest, but it is not easy to run in old houses. I have a home built in 1977, with two floors, service comes into the home through the basement. The basement has a finished ceiling. Also depending on the Cat-x cable you run only adds to the difficulty.
Wireless is the answer if it can go through walls, floors & ceilings, just requiring power - like AP or Extender, but no ethernet connectivity. I don't see how that Wifi can exist or be faster if it must communicate on the same bandwidth as the master router. This is why I asked if Netgear engineers can recommend hardware that we old farts can add to make our old equipment still usable.
Seems like what I did with 8-tracks, reel-to-reel & cassettes is all happening in this electronic age of networking.
I believe in this string of comments there was the statement the mesh environment does not work with the R9000. So we cannot add any of the Orbi's or that new technology?
- michaelkenwardMar 03, 2023Guru - Experienced User
Not sure that I can spot many connection between port aggregation and access to storage.
As I understand it, that is more to do with enabling faster Ethernet. But that isn't going to get you very far if you have attached devices that are stuck at a slower Ethernet speed.
At least a year younger than my house.
I use Powerline Ethernet to connect things. It does depend on the quality of the house wiring, but it can beat WiFi in ease and reliability.
I see no string of comment, just your first message and now two replies. Maybe you saw something elsewhere.
The R9000 does not support Mesh. But I have no idea where that suddenly came from. Perhaps another message that I haven't seen.
