TheRealkNoCKs
Jan 05, 2022Aspirant
I bought this from amazon
My is the XR1000, no idea why it wont let me add that. But my problem is I bought this router off amazon. It is certified refurbished, but I cant confiq my settings because my serial number is lo...
michaelkenward
Jan 06, 2022Guru - Experienced User
Two possible reasons:
- Too new for Netgear's database
- You put your question in the wrong place so it didn't recognise your device.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
