einshtin
May 18, 2022Tutor
I can’t access my router page 192.168.1.1
when i try to log in to the router page by writing in the browser 192.168.1.1, then enter Admin and password, it doesn't accept to log in and after trying three times the page give me the option to ...
michaelkenward
May 18, 2022Guru - Experienced User
And your Netgear device is? A model number?
Connected with what to the device? Wifi? Wired?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
einshtin
May 18, 2022Tutor
Netgear R7000
Connected with what to the device? Wifi? Wired? I tried to connect my laptop to the netgear with the two options wired and wireless.
What firmware version do you have on the device? I reset the netgear many times and I don't have access to the router page to update it.
Netgear R7000
- michaelkenwardMay 18, 2022Guru - Experienced User
And the modem?
If this is a modem/router that can interfere when the browser looks for the address 192.168.1.1.
That's why we ask for the make and model number. Many ISPs provide modem/routers to customers.
Did you find this?
If you cannot login to your router | Answer | NETGEAR Support
