einshtin
May 17, 2022Tutor
I can’t access my router page 192.168.1.1
when i try to log in to the router page by writing in the browser 192.168.1.1, then enter Admin and password, it doesn't accept to log in and after trying three times the page give me the option to ...
einshtin
May 18, 2022Tutor
Netgear is connected to Modem (which is also include router) Hitron model : CODA-4680
michaelkenward
May 18, 2022Guru - Experienced User
If it really is a modem/router – Google isn't clear – that could be the source of the problem. The Hitron might also have a similar login address or it is intercepting attempts to get to 192.168.1.1.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
Hitron models Bridge Mode - TekSavvy Community
Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
It may be that your R7000 spotted the CODA-4680 on setup and picked a different IP address. As some of the manuals say:
"If the router detects a conflict with a WAN IP address,it changes its IP address to 10.0.0.1 or 172.16.5.1"
You could try them.
