einshtin
May 17, 2022Tutor
I can’t access my router page 192.168.1.1
when i try to log in to the router page by writing in the browser 192.168.1.1, then enter Admin and password, it doesn't accept to log in and after trying three times the page give me the option to ...
einshtin
Jun 03, 2022Tutor
I tried 172.16.5.1 and 10.0.0.1 and even i changed the modem to a modem without router.
and i still don't have access to router page
michaelkenward
Jun 04, 2022Guru - Experienced User
I don't know what that means or what you are doing. Your description needs to explain what you do step by step.
Is this the "modem" you have?
DOCSIS 3.1 Cable Modem Router | CODA-4680 | Hitron Americas
If so, it is a modem/router that is "Only sold through Service Providers".
This has its own login address. (By default it is 192.168.0.1.) So it is no surprise that your browser gets "lost" between two routers trying to tell it where to go.
To get it to work effectively with your Netgear router, you may .like to put it into modem only (bridge) mode:
hitron coda-4680 bridge mode - Google Search
When you have done that, remember to reset the Netgear router and set things up from scratch.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
