MikhaelS
May 29, 2021Tutor
I cannot connect to PSN (https://my.playstation.com/) from my PS4 using the WAC( wifi)
Hello, I have installed a WAC 510 and all computers and / or phones work without any problems. My PS4 has internet access when it is connected to the WAC, however, I cannot connect to PSN (https://my.playstation.com/). I connect to it without any problem when I use the WIFI of the main router, on the other hand this is impossible if I am connected by WIFI to the WAC. thank you in advance
1 Reply
MikhaelS wrote:
Hello, I have installed a WAC 510 ....
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but the WAC510 is a specialist device, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:NETGEAR Insight Network Management - NETGEAR Communities
This might help:
Search - NETGEAR Communities – WAC510
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
