ElDakaTiger
Oct 07, 2015Aspirant
I cannot connect to steam and world of tanks, But I can connect to every other site and server.
So how do I fix my router so that it will allow my pc to connect to steam and to world of tanks? I am a A+ certified computer technician and hold hardware certifications with several companies, yet e...
- Oct 08, 2015I agree, especially since you said that it doesn't work when connected directly to the modem. That's proof that the router is not involved.
ElDakaTiger
Oct 08, 2015Aspirant
Ping to both sites works fine, tracert is timing out before the first gateway. I tested doing an update on a pc only connected by WIFI and it worked fine.
I think it has to do with LAN connection's only so config problems, or the hardware itself is at fault.
TheEther
Oct 08, 2015Guru
Are you saying that you can connect to steam over Wi-Fi, but not over Ethernet? That's very strange.
It's also unusual for ping to succeed and traceroute to fail, though it's not unheard of. Sometimes, ISPs block traceroute packets in their network. But if your router is the first gateway, then it should be responding to traceroutes. Can you post your ping and traceroute output?
- ElDakaTigerOct 08, 2015Aspirant
They did go through today, but not after timing out. I can get to the websites for the programs but the programs are not going through.
