Odshr8er
Apr 23, 2022Follower
I cannot get my new nighthawk 6 router to connect to my laptop. It says the password fails
The same password works with my smartphone
michaelkenward
Apr 24, 2022Guru - Experienced User
Rather than "cannot get my new nighthawk 6 router to connect to my laptop", as you describe in the subject, it is better to think about this the other way round and getting the laptop to connect to the router. Unless you have set it up to block devices, the router doesn't do much in the process beyond providing the wifi.
Tell your laptop to forget any connection to the SSID and set it up from scratch. You don't want it remembering old passwords.
And what happens when the laptop tries to connect? Connect how? What says "the password fails"?
