watarusan
Jul 31, 2021Aspirant
I can't connect to 316 424 because they are online (VPN disconnected). Is there any way to fix this?
On MacOSBigSur11.5 + MacbookAir (M1 processor), I am unable to connect to ReadyNAS316 and 424 with readycloud app (Ver1.7). I can't connect to ReadyNAS316 and 424 because they are online (VPN discon...
- Aug 01, 2021
watarusan wrote:
I can't connect to ReadyNAS316 and 424 because they are online (VPN disconnected). Is there any way to fix this?
Is this a genuine message or just a plant for linkspam?
If genuine it is posted in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
ReadyNAS is nothing like a router so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
I will ask the Netgear moderator to move your message.
michaelkenward
Aug 01, 2021Guru - Experienced User
watarusan
Aug 09, 2021Aspirant
Hello.
Thank you for pointing out the error.
It doesn't show up when I reply to you, so this message is
I hope this message reaches michaelkenward.
