Gregory840316
Feb 18, 2021Aspirant
I can`t connect with the Internet
Hello! My English is very weak, but I hope you will be able to understand what I mean. I have bought Netgear AC4000 and I have been trying to connect it to the Internet for 3 days so far. I switch m...
Gregory840316
Feb 19, 2021Aspirant
My modem is NetiaSpot. I updated firmware. Do I need change anything in my modem settings? For example BRIDGE option?
michaelkenward
Feb 19, 2021Guru - Experienced User
This does not tell us enough about the modem. Is that the only bit of kit that NetiaSpot makes?
Does it have a model number? Is it also a router? (Many modems are also routers.)
If that is an option on the modem, then it is probably a router and you could try that to avoid this:
What is Double NAT? | Answer | NETGEAR Support
