Edenh0720
Feb 04, 2024Aspirant
I can't get in to the netgear genie to reset my admin password
I need a help as my router setup for long time ago. And i got a trouble as my r7000 lost the connection with the red light. I tried to log in the app and i want to update the firmware as well but i fo...
microchip8
Feb 04, 2024Master
You'll have to do a factory reset (button at back) as password reset is broken and sends you in a loop. The button at back you can press for 10 seconds and then use the default user and password to login.
