Edenh0720
Feb 04, 2024Aspirant
I can't get in to the netgear genie to reset my admin password
I need a help as my router setup for long time ago. And i got a trouble as my r7000 lost the connection with the red light. I tried to log in the app and i want to update the firmware as well but i fo...
Edenh0720
Feb 17, 2024Aspirant
Thank you for your help. And now i am trying to reset my R7000. But i am facing a funny issue which is the nighthawk app not found my router. The power is on and network cable connected from modern to R7000. Nighthawk said my router not found. Local network is enabled on my iphone setting. But still doesn't work to set up. Is something wrong on my setting process?
Feb 17, 2024Guru - Experienced User
