NWMichelle
Feb 05, 2019Tutor
I can't log in with admin/password... R7000
I am trying to login and see what's on my network (and to get my RING devices on the right 2.4 channel) but the website will NOT accept admin and password AND it will not accept my serial number (the...
- Sep 17, 2019Thank you to everyone who provided suggestions. I ended up downloading the Netgear app ( I forgot the exact name, maybe Netgear UP) and was finally able to get into the login screen where all the router settings are located.
I then had to reset all the parameters fresh and now it’s working fine.
microchip8
Feb 05, 2019Master
are you trying to connect to the router'e GUI at http://192.168.1.1 ?
if so, it should not ask you for any serial numbers, only user and admin which by default are "admin" and "password"
NWMichelle
Feb 05, 2019Tutor
Yes. I tried that address. I tried all this: By default, your NETGEAR home router's IP address should be assigned as either 192.168.1.1 or 192.168.0.1. You should also be able to access your router by typingin http://www.routerlogin.net or http://www.routerlogin.com into your web browser's address bar.
Then when at the page with admin/password, if you click cancel, it wants you to put in your serial number. It won't let me move past that screen.
