NWMichelle
Feb 05, 2019Tutor
I can't log in with admin/password... R7000
I am trying to login and see what's on my network (and to get my RING devices on the right 2.4 channel) but the website will NOT accept admin and password AND it will not accept my serial number (the...
- Sep 17, 2019Thank you to everyone who provided suggestions. I ended up downloading the Netgear app ( I forgot the exact name, maybe Netgear UP) and was finally able to get into the login screen where all the router settings are located.
I then had to reset all the parameters fresh and now it’s working fine.
PBukowski
Sep 15, 2019Aspirant
Antinode - you are a very rude person. If you are representing Netgear, you should be ashamed of yourself. Forget that I even posted anything. I will be all done buying Netgear products in the future. Instead I’ll purchase a $300 router from Asus. Maybe I won’t have to deal with insults from them.
michaelkenward
Sep 15, 2019Guru - Experienced User
PBukowski wrote:
If you are representing Netgear, you...
No.
This is essentially a user-to-user venue. Not everyone here takes pride in being rude.
Give the good guys a bit of time and the cavalry may ride in and rescue you.
