Fireblaster999's avatar
Sep 01, 2019
I cant port forward no matter what I do.
I've try to port forward using this router before and it work brilliantly. Today, when I try to port forward, it doesnt work.  I've try to fix it by: -Factory reset the router. (button and through ...
  • Fireblaster999's avatar
    Fireblaster999
    Sep 03, 2019
    I've found the solution. For me, my main PC does not connect my port to my public IP, therefore I use my old windows 7 laptop as a internal IP and the server. I port forward the server and went on canyouseeme.org and it see the port. The problem is,  probably, somewhere in my main PC, there is a Windows problem that doesn't allow the public IP to work. It probably can be fix with a new installation of Windows. Therefore, I use my laptop now to run the server and it work fine.
