GregerN
Mar 09, 2017Tutor
I can't port forward
What can I have done wrong here, i can't open ports. I've tried for 2 days now and yeah, It doesnt work for me. 1. https://gyazo.com/66325d22b943748d833f1a47f17c96f6 2. https://gyazo.com/43ac39a8fd...
- Mar 10, 2017
Log into your router. Click on the Advanced tab and look at IP Address listed under Internet Port. Reply with the first half of the address.
As to checking port forwarding, there needs to be a service running on the port you opened. What service are you trying to run?
TheEther
Mar 10, 2017Guru
Do you have a service running on 192.168.1.19 that is listening to port 1604?
Does your R7800 have a public IP address (i.e. 95.143.x.x) on its Internet/WAN port?
P.S. For privacy, you shouldn't share your public IP address. It's visible in one of your pictures.
- GregerNMar 10, 2017Tutor
Nothing is using the port because I've tried with many ports.
I dont understand the wan thing but I found this.
- TheEtherMar 10, 2017Guru
- GregerNMar 11, 2017Tutor
I didnt know that a service had to be running on the port I opened. I started it and checked the port and it worked, ty.
