abbotn
Mar 08, 2022Follower
I can't stand when my router reboots
Remember in the mid-90's when people used to complain about Windows rebooting every time they installed any piece of software? That was 25+ years ago. Microsoft listened made changes to their OS to r...
Mar 08, 2022Guru - Experienced User
You gave us nothing to go off. If it reboots on it's own, means there is a problem that needs to be troubleshot and figured out.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- plemansMar 08, 2022Guru - Experienced User
I think the OP is just stating its annoying how when you make changes in the gui, half the time the router has to reboot or it takes forever to change. It is a bit annoying.
- FURRYe38Mar 08, 2022Guru - Experienced User
Older routers, how they had the code setup. Newer one it's much less seen thought some major changes are still seeing a reboot.
