abbotn
Mar 08, 2022Follower
I can't stand when my router reboots
Remember in the mid-90's when people used to complain about Windows rebooting every time they installed any piece of software? That was 25+ years ago. Microsoft listened made changes to their OS to r...
Mar 08, 2022Guru - Experienced User
I think the OP is just stating its annoying how when you make changes in the gui, half the time the router has to reboot or it takes forever to change. It is a bit annoying.
Older routers, how they had the code setup. Newer one it's much less seen thought some major changes are still seeing a reboot.
