maskim1990
Feb 13, 2024Aspirant
I couldn't get a Wi-Fi signal
I'm having the same problem, after upgrading to the latest firmware I couldn't get a Wi-Fi signal so I downgraded the firmware to a lower version but still couldn't fix it, reset multiple times and s...
michaelkenward
Feb 13, 2024Guru - Experienced User
maskim1990 wrote:
I'm having the same problem, after upgrading to the latest firmware I couldn't get a Wi-Fi signal so I downgraded the firmware to a lower version but still couldn't fix it, reset multiple times and still couldn't fix it.
Start with the simple one, is the wifi on/off button pressed? Do the wifi LEDS come on?
The next one is to restart the network.
Be sure to reboot your network in this sequence:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If that doesn't get you anywhere, the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Having two routers on a network can cause headaches. For example, you can end up with local address problems.
I have damage to the bottom of the antenna housing, not sure if that has any effect?
Was it working with that damage and before the firmware update? If so, you should have no problem.
I assume that the power LED is as expected and not showing any signs of broken firmware and that there are no problems with the power supply.
