lalascott7
Oct 07, 2020Aspirant
I get "issues connecting to.." Error
This is so frustrating!!!! I don't understand what's tiny on with my app but everytime I connect to the right network I still cannot get it to detect my nighthawk router!!! I have tried set up 2xs and...
- Oct 07, 2020
> [...] my nighthawk router [...]
Has your (unspecified) "my nighthawk router" a model number? Look
for "Model" on the product label.> Model: A6200|802.11ac Dual Band WiFi USB Adapter
Not a router.
> [...] Is there a better way to just get this firmware update besides
> using the app?
_Which_ "this firmware update"? Are you trying to do a firmware
update?Forget the (unspecified) "my app", and use a web browser? Visit
http://netgear.com/support , put in your (actual) model number, and look
for Documentation. Get the User Manual. Read. Look for "firmware".
Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads. (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".) Find the
kit(s). Download the kit(s) you want. Read the "Release Notes" file
for instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)Failing a helpful User Manual:
antinode
Oct 07, 2020Guru
Not a router.
> using the app?
update?
- antinodeOct 07, 2020Guru
Note that many people recommend using a computer with a wired
connection to the router for this, rather than any wirelessly-connected
device. - lalascott7Oct 07, 2020AspirantOk cool. Yes I realized that about the type of model. It's an R6230 nighthawk dual-band router.
I am going to go to my pc to install firmware on my device. And I'm going to forget about the app, right? If that's so I appreciate your help. 🙂 - lalascott7Oct 07, 2020AspirantYes firmware update. I got an ema6from Netgear about it.
