zibonvil
Jul 27, 2024Aspirant
I got a NH from a friend and it’s troublesome
So like the title suggests I am having issues with a NH router I got from a buddy it stops broadcasting WiFi it’s a older model I believe it’s the ac1900 R7000
1 Reply
Firmware on it?
What happens when it stops? Are the led's still on for wifi?
Are you able to connect via ethernet and log in and check it?
A few more details help.
Also, it might be worth checking with your friend why they stopped using it. that router is a decade old and there might be a reason it was retired.
