kreansanm's avatar
kreansanm
Follower
Mar 20, 2023
I have a Netgear nighthawk R6900 router
I have a Netgear nighthawk R6900 router. Recently (6 months) it frequently drops the internet connection and requires a reboot to reconnect. My ISP connection is intact. Could this be from a hiccup from my ISP causing the router to drop or is it problem with my router. I have the latest firmware available.
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Does the Internet LED change to a AMBER color or turn OFF when this happens?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
