Bill1944
Mar 13, 2023Aspirant
I have a Nighthawk AC3200, Model 8000.
my Router is receiving signal from Spectrum at 315 mbs, but the output wifi signal ranges from 55 to 105 mbs. how do I correct this so I am getting the full wifi speed?
Mar 13, 2023Guru - Experienced User
What modem/gateway is it connected to?
what firmware is on the router?
If you're using qos, access control, traffic monitoring, or parental controls disable them and reboot the router.
then retest.
What device are you testing on?
Are you connecting to the 2.4ghz or the 5ghz band? (hint, 2.4ghz is a slow band and sensitive to interference)
