Bill1944
Mar 13, 2023Aspirant
I have a Nighthawk AC3200, Model 8000.
my Router is receiving signal from Spectrum at 315 mbs, but the output wifi signal ranges from 55 to 105 mbs. how do I correct this so I am getting the full wifi speed?
microchip8
Mar 13, 2023Master
Which wifi client/device you're using to test speeds?
What firmware version is on the router?
Which wifi band you talk about, 2.4 or 5 GHz?
Bill1944
Mar 14, 2023Aspirant
Thank you for responding
I have an Arris BS6183 Modem. seems to be performing ok (at rated 850mbs)
the firmware model 8000 is V1.0.4.84_10.1.84
I am using the 2.4 gh, the 5.0 is no longer available. I assume I lost it on some upgrade???
thank you again
- plemansMar 14, 2023Guru - Experienced User
The R8000 uses smart connect that combines the 3x bands into one.
You can try disabling that and testing each band. Maybe you're speeds were related to being on the 2.4ghz
- KitsapMar 15, 2023Master
Bill1944 wrote:Thank you for responding
thank you again
Bad assumption. Most likely your have smart connect enabled like plemans indicated.
Disable smart connect and make sure you have different SSID's configured so you can tell the difference between the 2.4 and 5 GHz bands on the devices you are using to connect to Wi-Fi.
