Bill1944
Mar 13, 2023Aspirant
I have a Nighthawk AC3200, Model 8000.
my Router is receiving signal from Spectrum at 315 mbs, but the output wifi signal ranges from 55 to 105 mbs. how do I correct this so I am getting the full wifi speed?
Bill1944
Mar 14, 2023Aspirant
Thank you for responding
I have an Arris BS6183 Modem. seems to be performing ok (at rated 850mbs)
the firmware model 8000 is V1.0.4.84_10.1.84
I am using the 2.4 gh, the 5.0 is no longer available. I assume I lost it on some upgrade???
thank you again
Mar 14, 2023Guru - Experienced User
The R8000 uses smart connect that combines the 3x bands into one.
You can try disabling that and testing each band. Maybe you're speeds were related to being on the 2.4ghz
