Jashfield
Jun 18, 2017Aspirant
I have a r7000 and am logged into genie , I want to restrict users after 12 midnight,
I am having trouble trying to restrict users through the genie app to stop access to the network after 12 midnight, even though the restriction are put in place, wifi and Ethernet on the pc's seem t...
- Jun 20, 2017Ok thanks for the help
Jashfield
Ok I will look into this, i am happy to literally turn of the router at midnight if I have to, what is radios time ?
Rhyalus
Jun 20, 2017Apprentice
Go to Advanced / Advanced setup / Wireless Settings
Add new periods for both 2.4 and 5 GHz radios. I use 12am to 530am.
Make sure to check the boxes "Turn off wireless by schedule".
Works fine...you can also "override" this and turn the wireless on or off from the button on the front of the router.
R
