Jashfield
Jun 18, 2017Aspirant
I have a r7000 and am logged into genie , I want to restrict users after 12 midnight,
I am having trouble trying to restrict users through the genie app to stop access to the network after 12 midnight, even though the restriction are put in place, wifi and Ethernet on the pc's seem t...
- Jun 20, 2017Ok thanks for the help
Jashfield
Jun 20, 2017Aspirant
Can you restrict the wired connections then or not
theroys88
Jun 20, 2017Apprentice
Check your network daily. Once the little ones figure out how to change their address then the feature is useless. As long as they do not know, the features on these parental control and time limits work fine. Once they figure it out, the only option is a PC based filter software program which has to be installed on each individual computer.
