Jashfield
Jun 18, 2017Aspirant
I have a r7000 and am logged into genie , I want to restrict users after 12 midnight,
I am having trouble trying to restrict users through the genie app to stop access to the network after 12 midnight, even though the restriction are put in place, wifi and Ethernet on the pc's seem t...
- Jun 20, 2017Ok thanks for the help
Jun 20, 2017Guru - Experienced User
Can also look into some DDNS services as well for additional parental controls. DynDNS and OpenDNS are a couple to check out.
theroys88
Jun 20, 2017Apprentice
I found Open DNS to be pretty much worthless when I used it stand alone and then on my Nighthawk. Porous is the word I would describe it as. The only real effective parental control software are the ones that one must individually install on each computer. Clearplay and Netnanny are some that are effective.
