Olddude2023
Jan 02, 2023Follower
I have a r7200 router
I got this router (r7200, ac2100) because it said it was VPN compatible. I am attempting to use nordvpn as a router VPN but it seems this router, even though it says VPN compatible is not compatible. ...
Jan 02, 2023Guru - Experienced User
I would review the user manual on what VPN configuration maybe used on the router.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Also contact NordVPN on how to configure and connect to there VPN since that there product.
