Nikkofury
Jul 19, 2021Aspirant
I have an AC1900 Netgear Nighhawk Router that doesn't work with Spectrum, do I need to change router
Hello, I have a Nighthawk router AC1900 that I've used for a few years, recently got Spectrum services and it doesn't seem to be compatible, just switched from ATT Fiber. I updated the Firmware t...
Jul 19, 2021Guru - Experienced User
what actual router do you have? AC1900 is a speed
What modem/gateway do you have from spectrum?
who told you it doesn't work with spectrum?
Details are key as I haven't found a router only device that won't work with spectrum.
Nikkofury
Spectrum Wave 2
R6900 gigabit I believe
When the technician hooked it up the internet showed to be red and wouldn't work, we rebooted the router and reset it to no avail. Then I updated the firmware which didn't work as well. The Wave 2 provided by Spectrum isn't very good either.
- plemansJul 19, 2021Guru - Experienced User
Spectrum has 3x wave 2 routers.
Try putting the R6900 in access point mode and connecting it to the spectrum device.
- NikkofuryJul 19, 2021Aspirant
Will try that, thank you!
Update on equipment
AC1900 R7000
RAG2V1K Spectrum Router
So I set it up as an AP and the internet does work now, however I don't see the 5G option come up on WIFI anymore, and when I connect it seems to have to *configure* often when I connect to some devices: Laptop,phone etc. It's like the internet comes available on and off?
When it does work though it works great across the house, better than the Spectrum Router.
You're insight is greatly appreciated.
Best regards,
Nikkofury
- plemansJul 20, 2021Guru - Experienced User
Do you have the R6900 or R7000?
Also, if you're using smart connect, it combines the 2.4ghz and 5ghz into a single ssid. They won't show as seperate unless you disable smart connect and name the ssid's different
