peterjedi
Oct 12, 2021Follower
I have RAX 70 Router
Hello, The router works fine, but I am not getting any reception in the back yard. I am thinking of doing the following options: 1) Get another router to do Access Point (wired) to my RAX 70 ...
michaelkenward
Oct 13, 2021Guru - Experienced User
FURRYe38 wrote:
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products.
Feel free to go there if you must, but that is not the best place to ask about wifi extenders. It just wastes your time and makes this place even messier than it needs to be.
Extenders are generic things that apply to any router you own, RAX or otherwise.
There is a separate place for extenders:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
But that can suck you into another black hole.
plemans has already asked some key questions. But my first call would be on the product pages for extenders.
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
Feed in your needs and the local details and see what comes up. Check back here for reports things that take your fancy.
Please tag the OP user. Not me. I already know where posts should be.
Thank you.
