levaneliz
Feb 01, 2022Aspirant
I lost wifi connection at all
Suddenly all the lights on the Wi-Fi are off. only one light is on: Wi-Fi on/off button To make it clearer I am uploading a picture. Please tell me what I can do to fix it? power light is off in...
Feb 01, 2022Guru - Experienced User
Try a power OFF of the router and ISP modem for 1 minute then back ON?
levaneliz
Feb 02, 2022Aspirant
I have tried it. but no result
- michaelkenwardFeb 02, 2022Guru - Experienced User
If the power light doesn't come on, that suggests dead hardware.
If you have a compatible powder adapter lying around, they are pretty common, try that. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
If that does not work, then it may be time to recycle your eight-year old router.
By the way ac1750 doesn't tell us which router you own.
ac1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. Look at the label on the device for the model number.
- levanelizFeb 02, 2022Aspirant
R6700|Nighthawk AC1750 Smart WiFi Router
