thedjskeletor
Jul 29, 2021Follower
i need a mobile router as a mobile dj i need access anywhere also want to use in my cabin
Please help i need a great mobile router
as a moble dj i need access to,the internet wherever i work plus i have a field office and a camper possibly need one with an additional outside ariel
currently hace a tp link....its aweful gets around 2mbps on a good day and there is zero help from their support line
i have tried constantly for 3 days unable to connect with anyone plus the other number they give you to call as a 24/7 access line does not work useless is a good word to describe them
i have an
100gb /pm ee sim
please help with advice
gerry
when you want the best dj i am your man
1 Reply
- davidm22Aspirant
For mobiler router , i can suggest you to buy Netgear AirCard 797 Mobile Hotspot.. the basic features are the following.
- Get 4G LTE and 3G Speeds Anywhere
- Connect up to 15 Wi-Fi-Enabled Devices
- Removable Lithium-Ion Battery
- Up to 11 Hours of Use
I hope this will helpful suggestion.
Thanks
David
