mike987
Jul 14, 2021Follower
i need to know how to set up nighthhack app without qr code
i bougth the rx300 night hwak gameing router but it did not come with QR code so i cant set up the app
1 Reply
You can sets it up using the installation assistant.
Either connect to the wifi or hardwired in. then log into the routerlogin . net and install that route.
It might pop up saying "use the app or qr code" but you can scroll down to the botton and there should be an option to use the device you're on.
