Oct 16, 2021Aspirant
I need to replace my N600 any suggestions
- Oct 16, 2021
Might try one of these:
https://www.netgear.com/home/wifi/routers/rax42/
Though if you have multi levels in the home a extender maybe needed or you might try a MESH system:
Maybe a MK series:
https://www.netgear.com/home/wifi/mesh/mk62/
Or Orbi series:
https://www.netgear.com/home/wifi/mesh/rbk12/
Other systems:
Oct 16, 2021Guru - Experienced User
What is the size of your home? Sq Ft
There are many router models to choose from.
What are you needs?
171
Provider:
Skyline/Skybest
Boone NC
I currently have a N600 WNDR3400 Yep its a tad old & WiFi Ext
House size apprx 2800sqft 3 levels Log Home
Devices: 1ea Laptop-2ea Ipads-2ea Cell-7ea TV all stream w/Youtube TV Live
Retired Couple w/2ea Grandsons that visit & they watch Youtube & some gaming
Providers Web-Site stats no combo unit / We never have had issues with providor
I hope this info helps & Thanks for your help & promtness
- FURRYe38Oct 16, 2021Guru - Experienced User
Maybe a MK series:
Or Orbi series:
Other systems:
