chanduzalte
Mar 01, 2021Aspirant
I want to use it as extender, How to setup WDS R8000 Nighthawk X6 AC3200
I have wifi dongle, it's jioFi.
I want to extend it's wifi range by using my netgear router as extender, How do I set up WDS on my netgear router ?
model is
R8000 — Nighthawk X6 AC3200
The R8000 doesn't have an extender mode. You could hardwire it in and use it as an access point.
- chanduzalteAspirant
plemans Thank for replying, But I'm not getting you.
could you please elaborate more on "HardWire"?and .. CM2000-> RAX200-> GS716v2-> EX8000
What are thsese numbers ? are these model numbers of routers ?
chanduzalte wrote:Thank for replying, But I'm not getting you.
could you please elaborate more on "HardWire"?----In access point mode, the R8000 needs to be connected back to the primary router using a hardline. Meaning ethernet. That could be done using just an ethernet cable, using a powerline connection, or even using moca adapters (ethernet over coax).and .. CM2000-> RAX200-> GS716v2-> EX8000
What are thsese numbers ? are these model numbers of routers ?----Its my signature with my current setup I'm using.
