firefox111
Sep 21, 2021Apprentice
I will be replacing my Nighthawk X6S R8000P
I finally decided that enough with this piece of crap. After a few days of research on what I should replace it with, I got an email from Costco that they are discounting the Nighthawk AX6200 (RAX78...
Sep 22, 2021Guru - Experienced User
When you get the new one, you can always use the old router as an access point.
If you hardwire it into the RAX78 and run the R8000P in access point mode, it functions pretty well.
You could either leave it by the RAX (on seperate ssid/wifi channels) to offload the primary router or you could position it somewhere else around the home for added coverage.
Or you can sell it to recoup some of your loss. Its still a well selling device.
firefox111
Sep 22, 2021Apprentice
I still have 2.4 GHz wireless G cameras in my network. If the RAX78 will not support those devices, I will be forced to use the X6S as AP just for the old wireless G devices.
