JimRessler
Oct 12, 2021Guide
If your R7000P drops WIFI, check that it's not overheating
There is hope, don't throw away your R7000P router for dropped signal. Raise it up off the surface or point a fan at it to keep it cool. When the top of the case was 95 and the bottom was 106, WIFI ...
labatt
Oct 12, 2021Mentor
Folks have reported poor grease used for the heat sinks. Some have said they took router appart and replaced the grease with good success.
JimRessler
Oct 27, 2021Guide
The R7000P does not use grease, it uses thermal pads. I drilled 52 holes in the top cover, been good ever since.
