therealdoodle
Aug 29, 2022Aspirant
IInternet Usage by Device not working - R7900
Hello, I have someone on my home network who is using 50+GB of data per day and I need to know who's device it is so I can talk to them about it. I have enabled Dynamic QoS and when I select the...
Feste
Aug 29, 2022Initiate
Apparently, it only shows a snapshot of the bandwidth usage by device. hitting the refresh button will take another snapshot. it doesn't track cumulative usage by device, only the current Mbps by device. Also, you might change the priority. Do this by clicking on the check box by the device name, the scroll to the top and select "edit". If you find the culprit, you can give them a low QoS priority. I'm frustrated by the same issue and wish netgear would allow admins to set a duration of time to accumulate total data usage by device.
- therealdoodleAug 30, 2022Aspirant
Interesting, I know that when I clicked on it, there were at least two people streaming either Netflix or something else which makes me think it is not taking a snapshot at all.
- michaelkenwardAug 30, 2022Guru - Experienced User
True. That is one of the things that people ask for.
Traffic monitoring is a very blunt tool on Netgear's routers.
