Neenas
Aug 26, 2017Tutor
I'm looking for the privacy separator on nighthawk 1750 model R6700
Can't print but printer is on the network
- Aug 27, 2017
Finally figured it out. On each device where the net gear genie is installed the access control must be "on".
Neenas
Aug 27, 2017Tutor
michaelkenward
Aug 27, 2017Guru - Experienced User
Well done. Nice detective work.
The genie is just changing the settings on the devices. It should work without the genie, but why make life harder?
PS If you mark your "fixed" message as "Solved" it could help someone who turns up later with the same problem.
