cdysthe
Jul 04, 2016Virtuoso
I'm on V1.0.6.54_1.2.3 and it's perfect!
Hi, I am one of those who do not underand all the complaints around firmware for the R7000. I have had minor problems with a couple of releases, but not anything serious, However, after I got V1....
- Jul 08, 2016
As far as I understand V1.0.6.54_1.2.3 is not the version that was pulled. The version pulled was R7000-V1.0.6.40_1.1.90.chk
V1.0.6.54_1.2.3 seems to be the newest beta that has been published. But since the way Netgear names it's firmware updates in more mysterious ways than even the creator of our universe could come up with, it is understandable that you lost track.
So first:
-Find out if it is true what I say ( it always is.... ;-)
-Then ask yourself if you want to become a beta freak for Netgear ( hahahahahha)
-Then consider that the latest 'officially stable' firmware for R7000 is:
V1.0.5.70_1.1.91
And then think what you want to do. Use V1.0.6.54_1.2.3 or V1.0.5.70_1.1.91.
You could try V1.0.5.70_1.1.91 and tell me what you think. If you think V1.0.6.54_1.2.3 is better, I will try that too!
Retired_Member
Jul 05, 2016When the router manufacture pulls a FW version you can bet it has problems. Some people either don't realise they have a problem or don't use an option that has a problem.
When turning off WIFI via software or front button on router I EXPECT ALL WIFI and or RF to be TURNED off. That wasn't the case.
If you are happy using it great others had problems with it that are well documented.
- cdystheJul 05, 2016Virtuoso
Thank you for the info. So which version would you say is the best choice right now? Also, is downgrading to an older version as easy as the upgrade? I have simply flashed the new version on top of the older and it has worked without even a factory reset.
- Retired_MemberJul 05, 2016
I cannot answer the question as to which is the best. What's best for your needs. This whole topic has been beat to death several dozen times in the past 24 months. I'm not about to reinvent the wheel again, Sorry. You should start reading the post written by members on the that subject and then forum your own opinion.
The beauty of a forum like this is the past problems have been saved for future reference, Happy Reading!
