smithjordan2196
Dec 21, 2020Aspirant
Im stuck in bridge mode and can't access genie
So i put my router in bridge mode and now i cannot access anything to get it out of bridge mode. I have reset my router almost 20 times and have tried using 5 different computers. I have tried going ...
michaelkenward
Dec 22, 2020Guru - Experienced User
smithjordan2196 wrote:
But it just restarts and then i still dont have access to change any settings
How are you trying to access the thing after the reset?
Disconnect it from everything and plug it into a PC that is also connected to nothing else. Then you should be able to use the usual access methods. They will not work if it is on the same network as something else.
smithjordan2196
Dec 22, 2020Aspirant
so i need to disconnect evrything from the router??? because as soon as i reset it all of my devices in my household automatically connect
