smithjordan2196
Dec 21, 2020Aspirant
Im stuck in bridge mode and can't access genie
So i put my router in bridge mode and now i cannot access anything to get it out of bridge mode. I have reset my router almost 20 times and have tried using 5 different computers. I have tried going ...
michaelkenward
Dec 22, 2020Guru - Experienced User
smithjordan2196 wrote:
It was suggested that i try and put my R7450 into Bridge mode to see if that resolved those issues, which it did but then it caused even worse issues.
OK. Without a router in front of the R7450, suggesting bridge mode was strange advice.
People use "bridge mode" to describe many things. According to the manual for your R7450:
"You can use your router in bridge mode to connect multiple devices wirelessly... "
I admit that that could be clearer, but it doesn't mean that you can use bridge mode to fix problems with wifi devices. As the manual goes on to say:
You need two routers: one set up as a router and the other set up as a bridge.
That doesn't sound like anything you were trying to do. So we have no idea why anyone would advise you to put the R7450 into bridge mode. Did whoever suggested that offer any explanation as to why they thought it a good idea?
Back to the beginning:
Okay so my internet cable comes in to my house and connects directly to my R7450.
So there is no box on the wall that feeds into your router? Just a LAN port?
What sort of Internet is this? The only common ways in which the Internet arrives with nothing else involved is with optical fibre and an "ONT" (optical network terminator) or in an apartment where the whole place is wired for Internet fed from a collective router.
It might help of you told people who the ISP is and what sort of Internet is claims to deliver.
You said at the start:
I was expierancing issues with my internet. I was getting Double NAT errors on different devices.
Double NAT is usually caused by having two routers around. (It could be something else, but without details of those "issues" and the devices involved, who knows?) From your description, there is only one router.
If that hole in the wall actually feeds in from another router, then bridge mode is all wrong. But if you could experiment with "access point" mode as this is a well know way if dealing with Double NAT errors . Read the bit in the manual Use the Router as a WiFi Access Point.
Apologies if this is taking so long to result. But you may have start off with the bridge mode red herring while at the same time not telling us anything about this Double NAT thing. It took us nine messages to get to this possibly important factor.
Anything else you haven't told us about?
smithjordan2196
Dec 23, 2020Aspirant
Okay so my question is still How do i access the router to get it out of bridge mode. I know for a fact i put it into bridge mode and now i cant get it out of bridge mode
- michaelkenwardDec 23, 2020Guru - Experienced User
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
You say you have done that, but to get a router into bridge mode you have to change the settings.
Reset restores everything back to the "out of the box" settings.
It isn't clear to me what you are doing after you did those multiple resets. The exact details are important.
I would investigate what you should do next. Treat the thing as a brand new device that you have just taken out of the box.
You said at the outset:
I have tried going to routerlogin.net and also just typing in my ip address on all 5 different computers. I can not get anything to help
What are you doing and what happens when you do that? No error messages?
- smithjordan2196Dec 23, 2020Aspirant
so after i rest my router it slowly reboots back on and then i try and login to the router via routerlogin.net and i am still unable to do so
