smithjordan2196
Dec 21, 2020Aspirant
Im stuck in bridge mode and can't access genie
So i put my router in bridge mode and now i cannot access anything to get it out of bridge mode. I have reset my router almost 20 times and have tried using 5 different computers. I have tried going ...
DarrenM
Dec 23, 2020Sr. NETGEAR Moderator
You will have to find the new Ip address of that router. Typically the way to do this is to log into the router that isn't bridged and go to the attached devices find the other router's IP address and then put that IP address in your web browser. That should prompt you with the login for the R7450.
smithjordan2196
Dec 23, 2020Aspirant
Okay but seems i dont have another router plugged in i cant do that.
- DarrenMDec 23, 2020Sr. NETGEAR Moderator
ok if you do not have another router plugged in you can try this. I linked how to find your default gateway that will be the IP address you want to use.
https://www.noip.com/support/knowledgebase/finding-your-default-gateway/
DarrenM
- smithjordan2196Dec 23, 2020Aspirant
so if i go to the default gateway it does bring up a different login than normal but my log in credentials do not work for it
- michaelkenwardDec 24, 2020Guru - Experienced User
Your own login credentials for router management will not work because the reset has wiped them out.
Try the factory defaults.
