smithjordan2196
Dec 21, 2020Aspirant
Im stuck in bridge mode and can't access genie
So i put my router in bridge mode and now i cannot access anything to get it out of bridge mode. I have reset my router almost 20 times and have tried using 5 different computers. I have tried going ...
smithjordan2196
Dec 23, 2020Aspirant
Okay but seems i dont have another router plugged in i cant do that.
DarrenM
Dec 23, 2020Sr. NETGEAR Moderator
ok if you do not have another router plugged in you can try this. I linked how to find your default gateway that will be the IP address you want to use.
https://www.noip.com/support/knowledgebase/finding-your-default-gateway/
DarrenM
- smithjordan2196Dec 23, 2020Aspirant
so if i go to the default gateway it does bring up a different login than normal but my log in credentials do not work for it
- michaelkenwardDec 23, 2020Guru - Experienced User
Your own login credentials for router management will not work because the reset has wiped them out.
Try the factory defaults.
