smithjordan2196
Dec 21, 2020Aspirant
Im stuck in bridge mode and can't access genie
So i put my router in bridge mode and now i cannot access anything to get it out of bridge mode. I have reset my router almost 20 times and have tried using 5 different computers. I have tried going ...
michaelkenward
Dec 23, 2020Guru - Experienced User
smithjordan2196 wrote:
Okay so my question is still How do i access the router to get it out of bridge mode. I know for a fact i put it into bridge mode and now i cant get it out of bridge mode
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
You say you have done that, but to get a router into bridge mode you have to change the settings.
Reset restores everything back to the "out of the box" settings.
It isn't clear to me what you are doing after you did those multiple resets. The exact details are important.
I would investigate what you should do next. Treat the thing as a brand new device that you have just taken out of the box.
You said at the outset:
I have tried going to routerlogin.net and also just typing in my ip address on all 5 different computers. I can not get anything to help
What are you doing and what happens when you do that? No error messages?
smithjordan2196
Dec 23, 2020Aspirant
so after i rest my router it slowly reboots back on and then i try and login to the router via routerlogin.net and i am still unable to do so
