jelabarre59
Dec 09, 2019Star
Importing address reservations, Nighthawk R7000
At this stage of development, WHY do you still not have a way of importing/exporting things like address reservations? I have a spreadsheet of my machines/tablets/phones, and it would be really sim...
- Dec 10, 2019
antinode wrote:> [...] I need to manually set the bits with a magnetized needle.
I doubt that that would work well with modern, semiconductor devices.
> There's a dedicated suggestions forum somewhere, for just such
feature requests.The comment about a magnetized needle was sarcasm. You have heard of sarcasm I presume?
Yeah, I've made various suggestions over the years, I thought MAYBE they might have acted on some of them. But that would be too much like doing WORK.
No matter, this P.o.S. is going BACK to the store for my money back. And appropriate product reviews posted.
EDIT: Oh, BTW, don't bother replying, I already unsubscribed from the thread.
antinode
Dec 09, 2019Guru
> [...] WHY [...]
Presumably, because adding a command-line interface would be
difficult, and not justify the investment. And user errors would
increase impressively, along with support costs.
> [...] it would be really simple [...]
If it's all _that_ simple, then let us know when you've got it
working?
> [...] show me already entered devices in proper IP number order.
Put them in that way?
Close to twenty years ago, I used a Cisco 678 which had (only) a
command-line interface (with serial port or Telnet access), and I could
easily copy+paste port-forwarding rules, and so on, when I wanted to. I
could also misconfigure the thing pretty easily.
If you want professional-grade features, then get professional-grade
equipment?
jelabarre59
Dec 10, 2019Star
antinode wrote:> [...] WHY [...]
equipment?
Oh, sorry, someone might actually have to do some WORK on their products...
So you're saying I should have to DELETE all my entries and re-type them in order to have them sorted? And if I'm adding devices in the middle of the list, go through that all over again? Then WHY do we have an electronic device in the first place??? And if there's a mistake somewhere in the middle, delete them all and re-enter them again? Next you're telling me I need to manually set the bits with a magnetized needle.
"Professional Grade" equipment doesn't have parental controls/time controls. Next brilliant idea?
- antinodeDec 10, 2019Guru
> products...A little forum browsing ought to make it pretty clear that Netgear
has finite resources to apply to firmware problems on these routers,
many of which cause bigger problems than inconvenient data entry. I
_hope_ that they'd prioritize those resources in ways which would
probably do nothing to ease your pain.> So you're saying [...]
No, I'm saying that any resources which Netgear applied to your
complaint would be unwisely spent, given all the other, more important
problems which need their attention.> [...] I need to manually set the bits with a magnetized needle.
> controls. Next brilliant idea?If no one else has produced the device which you want, then you can
either pay someone to do it for you, or you can do it yourself. Or you
can wait for it to appear.As you may recall, you originally asked why some potentially
desirable features were not (already) available (phrased as if someone
from Netgear might be paying attention, and care.) I believe that I
answered that question (although my relationship to Netgear is, like
yours, only as a victim).There's a dedicated suggestions forum somewhere, for just such
feature requests. I assume that it's mostly a black hole, so I haven't
recorded its location, but I'd expect a Web search to find it without
very much difficulty.- labattDec 10, 2019Mentor
Other method of parental control is turn it off now! No wireless controls needed. Yes I have had kids. ;)
- jelabarre59Dec 10, 2019Star
> The comment about a magnetized needle was sarcasm. [...]
Thanks. I _never_ would have guessed. There's a corollary to
Clarke's third law: "Any sufficiently lame sarcasm is indistinguishable
from stupidity." (Or, at least, deserves to be treated as such.)
