DalySio
Jun 22, 2023Aspirant
In APP Configuration Errors when setting up Guest Network/changing SSID of 2nd and 3rd bands
Background: Originally setup system in 2021 and have had no issues since. Power surges in neighborhood this week caused a factory reset (or something similar), all my customizations were lost. I...
michaelkenward
Jun 23, 2023Guru - Experienced User
DalySio wrote:
I use a CenturyLink Modem to bring in high speed Internet. ALL SSID's are hidden and turned off of CL Modem so the only thing it does it it is hard cable the Internet directly into the Nighthawk Modem. This worked perfectly for more than two years so I understand how to configure these joint systems.
Turning off the wifi does not disable the router bit of your modem/router. So you are piling router on router, a recipe for chaos.
The fact that it worked before just means that the two devices configured themselves to coexist at some stage. If you have a backup of those old settings, then you could try restoring them. Failing that you are going to have to take the whole network through the setup process in the correct order.
The first thing to do is to forget about using an app to set up your network. This gives much less control than the browser graphical user interface (GUI).
Then you need to address the "two routers" issue.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
I've read all the Support materials and checked the community already.
I'm surprised that you missed the "double NAT" mentions. It usually crops up several times a day.
- DalySioJun 26, 2023Aspirant
Thank you for your detailed reply. When I set it up I was very careful to deactivate anything with the CL Modem that effectively was its router function, and unfortunately I didn't take any notes about what I did to effectively make it work great for almost 3 years.
I agree that there's a possibility of NAT errors and was hoping I wouldn't have to start from scratch but that may be what I need to do.
Again, I appreciate your comments.
- KitsapJun 26, 2023Master
Does your Century Link Modem/Router device have a model number?
Does your internet service come over a DSL connection?
CL Modem is a C2100T. It's an older model but we 100% own it. It became too slow as a router which is why I reconfigured it for modem only and bought the Nighthawk.
We have high speed fiber, not DSL.
We're very happy with our CenturyLink service and speed since they installed the fiber.
- michaelkenwardJun 27, 2023Guru - Experienced User
That is not normally how you "bridge" a modem router. It is impossible to disable everything associated with being a router. Hence the "NAT" hangover.
Deactivating things and adding a router may have done no more than prompting the new router to adapt its settings to work alongside the other router. Some Netgear routers can do this.
If you subsequently play around with the router, it may break those settings.
What you really need is a "mode" setting that disables all the router features. Not all modem routers have this option.
Your C2100T is a cable modem/router. It looks like it has a genuine bridge mode:
c2100t bridge mode - Google Search
Rather than trying to track down your long forgotten settings, the best strategy would be to do what Netgear, and most experienced users here, advise and to bridge the modem/router and then to set up the R8000P from scratch.
When you have done that create a backup of the router's settings so that the next time you have problems you have a fall back to restore.
