DalySio
Jun 22, 2023Aspirant
In APP Configuration Errors when setting up Guest Network/changing SSID of 2nd and 3rd bands
Background: Originally setup system in 2021 and have had no issues since. Power surges in neighborhood this week caused a factory reset (or something similar), all my customizations were lost. I...
michaelkenward
Jun 23, 2023Guru - Experienced User
DalySio wrote:
I use a CenturyLink Modem to bring in high speed Internet. ALL SSID's are hidden and turned off of CL Modem so the only thing it does it it is hard cable the Internet directly into the Nighthawk Modem. This worked perfectly for more than two years so I understand how to configure these joint systems.
Turning off the wifi does not disable the router bit of your modem/router. So you are piling router on router, a recipe for chaos.
The fact that it worked before just means that the two devices configured themselves to coexist at some stage. If you have a backup of those old settings, then you could try restoring them. Failing that you are going to have to take the whole network through the setup process in the correct order.
The first thing to do is to forget about using an app to set up your network. This gives much less control than the browser graphical user interface (GUI).
Then you need to address the "two routers" issue.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
I've read all the Support materials and checked the community already.
I'm surprised that you missed the "double NAT" mentions. It usually crops up several times a day.
DalySio
Jun 26, 2023Aspirant
Thank you for your detailed reply. When I set it up I was very careful to deactivate anything with the CL Modem that effectively was its router function, and unfortunately I didn't take any notes about what I did to effectively make it work great for almost 3 years.
I agree that there's a possibility of NAT errors and was hoping I wouldn't have to start from scratch but that may be what I need to do.
Again, I appreciate your comments.
