sayblog
Nov 21, 2021Aspirant
In R6220 netgear usb control center, there is no printer after Windows 11 upgrade
Hi all. I am using R6220. To use Canon G2900 inkject printer as wireless, I installed netgear usb control center on 2 laptops. In one of them, I upgrade OS windows10 to windows11. After upgrade...
- Nov 22, 2021
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalPlease refer to the printers Mfr for help and support information regarding there product.
Thank you
Nov 22, 2021Guru - Experienced User
Thank you
- sayblogNov 29, 2021Aspirant
So sorry for late reply.
Thank you so much for your help
- michaelkenwardNov 29, 2021Guru - Experienced User
